CT
TPer Emeritus
No doubt most of you will be aware that there seems to be a problem with this grip causing the 20D to not register the state of discharge of the battery on the top LCD panel. Apparantly Canon USA have acknowledged the problem, but Canon UK are denying the issue. I've been using the grip with two batteries inserted and seeing no sign of battery depletion on the LCD panel, I pulled out the batteries removed the grip and inserted each battery in the camera in turn. Sure enough, both batteries were showing partly depleted after a week of pretty well regular use. In fairness they were showing no sign of slowing down at all.
On the advice of another owner, I charged the batteries, but put them into the grip before inserting the grip in the camera, which is supposed to be a 'work around' for the problem. Two weeks later, I had arrived at the conclusion this didn't work as there was no sign at all of battery depletion. However after an extended period of use this morning, the LCD display did indeed show partial battery depletion, so it seems to work.
I have to say though that the battery life in this camera is so impressive, it's almost a none issue, as you'd undoubtedly charge the batteries before a day out, and if at home, the recharge time is very quick, and you can even do a partial quick charge. I've just spent over an hour trying to run the batteries dead and got fed up of trying, the camera is still capable of 6 shot bursts at full res. I've finally put one battery on charge and the other is still giving 6 shot bursts from the camera on it's own! :shock:
