I also have the "old" Nik software but when I began experimenting with Topaz on my Mac the Nik software had been crippled by Apple on the Big Sur OS "upgrade". It works on my Win10 PC but it hadn't occurred to me to compare Topaz with Nik, I'll have a go sometime.
You've nothing to worry about from a Nik perspective, at least not from mine or @Fuji Dave's experience (above) with C1One of the reasons I've stayed with Mojave.
I don't see what is the advantage of using a plugin in LR?
Anyway, it makes you export a TIFF, then denoise the TIFF to reimport it, then export a JPG.
It's not really a plugin it's just an automated export/import routine?
Ahh I've occasionally had it disappear after processing and wondered what happened! Do you have to sync the catalog folder in Lightroom to find it? I'm sure I've had them disappear from Photolab too - maybe it sends it back to my old Lightroom catalog.I've unfortunately re- discovered the problem i had earlier with Denoise AI.
When I ask Topaz to return the denoised file to its original location, it goes to the catalogue folder , rather than back into Lightroom. The unprocessed tif is still in LR which makes denoise appear not to have worked. I've had to go into the catalogue folder to find the denoised file and then re-import that into LR.
That is why I am /you are getting odd file names eg IMG-XXXX. denoise.denoise.tif.
That's a real pain and I'm sure its not meant to work like that. Will have to look into it. Topaz support was pretty good when i tried it before.
I've moved away from Lightroom now although I still dip into my catalogs and I find syncing the folder quicker than going through the import dialogue. I guess a search for the filename might be worthwhile but I'd always assumed it hadn't saved it, so I've probably got duplicates all over the place.I hadn't thought of trying to do that. maybe next time! I've contacted Topaz support. I read that if Denoise offers you a choice of where you want the file to be saved to, it's not working properly as a plugin.
