Yeah, combined with 2 stops of shadow recovery.I mean +50 clarity FFS!
My D800E has far more hot pixels than my D800 had for some reason. It's by far the worst camera I've owned for this? Am I bothered? Nope. If I'm not doing anything that relies heavily on immediately starting the next exposure.. and let's be honest... that pretty much means stacked star trails or time lapse... then I'll just select a user profile where I have set long exposure NR on. If I do need to open the shutter immediately again... then I'll shoot a dark reference frame and use one of the many pieces of software available to remove hot pixels.
It's only an issue with long exposures, and to some degree, al cameras do this. I can assure you my D800E is FAR worse than the D800E example image used in that article.
Why do people obsess and start the spreading stupid rumours that new cameras have "faults" when in reality.... it just suffers from thermal noise.. something pretty much all CMOS sensors will do if left on long enough. They'll be pasting up examples of amp glow next, and calling THAT a fault.
I mean +50 clarity FFS! Those dots would be hardly visible with no clarity, and who the hell uses +50 clarity except the HDR and Flickr crowd anyway? It looks crap.
I absolutely do not believe that D800E example either, especially if there is +50 clarity added. Looks like they left the Long Exp NR on with the D800E to me, as mine's probably worse than the D810 example they posted here.
I'll post up a version of mine later when it gets dark. I bet with +50 clarity it an''t so pretty either.... we'll see later.
Seriously.... scaremongering bull****.
I said this to him on his page and was told my issue is just hot/stuck pixels and the d810 is different.
Could this be from removing the lowpass filter. If this does end up being worse than a d800E which i found worse than my d800 it could explain it.
Anyone who owns the D810 might want to read this.
Photography Life have found a thermal noise issue with three D810 bodies. Their article includes instructions on how to reproduce it / find out if your camera is affected.
Thanks - but luckily doesn't effect me as I don't do long exposures!
BTW... your link wasn't working.. I think you meant this one?
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/61871
No, I meant the link I used in post 14 - to the serial checker. Select English in the dropdown & click Submit, then type in the D810 serial at the next screen & hit Check - the answer that comes up will tell you if the camera has the 'issue'.
Checked on my serial no today after an email from Nikon UK, and I've got one that needs to go back to Nikon.
They've sent anpost paid label just have to drop it into a post office.
But they're saying two to four weeks for repair!
Two questions, is that timescale acceptable for a camera that I've had for only three weeks? And is it worth sending in to repair a function that I'm probably not going to use?
The work I do with it, landscape, micro, portrait, shows no fault even blowing up to A2 print.Sorry.. thought you were trying to link to the article itself.
Have you actually checked it has a fault, or just assuming it has because of it's serial number? What Photographylife's images are showing in this thread is actually pretty normal. All my cameras do this. Would be a shame to send your camera way for up to four weeks for nothing.
I don't push this camera to the same extent as the testing done,simply because I don't do that. It's not my remit.
Just "black frame" tested mine and I get ZERO noise at a 1min exposure ISO 100 (and I mean NONE).
That it's affected.What does the serial number checker say about yours? (link in post 14)
I did most of what they suggested, just left out the clarity adjustment. And even pushing clarity to 100% it isn't bad at all. But push the exposure up a couple stops as well and the image looks like a confetti storm...Steve... I bet if you did to your RAW what Photographylife did (and I did in my test) you'd get noise. It's normal.
Well my new 810 arrived today and it has the problem according to its serial number.
I wonder if the UK service centre will deal with cameras bought through Panamoz?
Great
The only thing is if you at any time want to move this camera on,everybody going to ask "has it had the fix"
Why so upset. Why not test if it actually has anything wrong with it before you send it anywhere? Why send it back because of a number?
Not only that, you'd be doing others a massive favour too, as so far, the only pictures I've found of this "fault" are Photographylife's, and all they've demonstrated is completely normal behaviour for a digital camera. If yours behaves as expected, then that's two D810s in this thread that according to serial numbers, have a fault, but probably don't.
Body cap on. Manual. ISO100. Long Exposure NR OFF. Take a shot. See anything? No? Camera fine. In fact... do as Steve did and do a 1 minute exposure. Still OK? Definitely fine.
Yes and no I think... I've heard that ACR (LR/PS) has automatic hot pixel mapping so I used Capture NX-D this time. These are 100% screen shots of the D810 30 sec and 60 sec black frame exposures. Both have had their exposures pushed 4 stops. BTW, these shots were taken back-to-back so the 60sec would be more representative of a 90sec exposure for thermal noise.The longer the exposure, the greater it is, which would indicate it's a thermal condition of some sort, and not merely the effects of amplification.
By offering "a fix" right away; maybe they are hoping to prevent it being another issue like the D600 oil spot? They also include this disclaimer:With due respect to those who assume theres no problem, then why are Nikon offering a fix to a non existant issue??????
