- Danny
Ok this is a bit of a weird one to explain but hopefully it's an easy fix.
I've just bought a pair of Canon 6D's and I've noticed an issue that, if I wasn't going to be using them side by side, probably wouldn't be an issue at all.
When I'm in manual and rotate the top wheel/dial clockwise to adjust the shutter speed, on one body it increases the shutter speed (as it should) and on the other body it decreases the shutter speed (which just feels wrong). Obviously the same thing happens visa versa if I rotate anti-clockwise. This will be a real mind-bender when using them in tandem.
I've tried resetting the body that I think has the issue back to factory settings (that's the body where when I rotate the dial clockwise the shutter speed decreases) but no joy.
Any ideas would be greatly appreciated!
