- James
I have been trying to read up on the difference between crop sensors and full frame sensors. The problem is I feel a bit stupid as I cant really understand in laymans terms what the end result to a picture is...
I have a canon 20D which as I understand it is a 1.6x crop factor and I really want to buy a Canon 5D MK2 which obviously is full frame.
Now, in terms of the 2 cameras, if I waws to place them side by side with say a 50mm prime lens on them and take a picture, what would be different (apart from one bieng a lot higher res).
Would it be that one image would appear to be "zoomed in?" ie. When you put your 50mm lens on a 20D, it becomes effectively a 80mm lens (50mmx1.6=80), with the reduced field of view that an 80mm lens it would appear zoomed?
So me in my uneducated head says, cant I just walk closer to the subject to achieve a (true) 50mm photo, rather than shell out for a full frame?
Sorry for the noob questions just a little confused...
