- April 2008
Ok, am hoping someone can offer me some advice regarding studio lighting. I am looking to set up a small studio at work in a room measuring approx 10' x 12'. It will be used primarily for taking photographs of clothing on manequins and we'll be looking at taking just front shot, back shot, and maybe the odd detail.
My plan is to strip and whitewash (matt emulsion) one narrow end of the room and block up a small window with some self adhesive vinyl. I'm then wanting to get the shots taken so that they have a consistent plain background and require as little pp work as possible - this process needs to operate like a conveyor belt with thousands of garment styles to shoot and upload. So basically dress manequin, shoot, undress manequin, repeat. We don't want to have a setup where we're faffing about all the time moving lights or owt.
In order to achieve this I am thinking manequin as far in front of the white wall as space allows. Studio flash either side to blow out the background. Then hopefully a single studio flash to light the manequin. Expose for the garment, and with a bit of luck we'll have lovely clear shots with plain white backgrounds each time?
Does this sound correct?
We're working with a local college on this and they've recommended some kit...
Portaflash or Interfit
...is this where we should be looking?
Presumably we'll need some way of controlling the flashes, so is the best way to do this with some sort of wireless setup? Recommendations?
With regards to the camera, it would most likely be either a Canon 450D or I might sell works my 400D.
I won't be taking the shots myself, but it is my department so am in charge of setting this all up etc and I like to know as much about everything as possible. I appreciate we're going to be on a massive learning curve with this, so my main concerns at this stage are that we invest in the right equipment to do the job well. I can't afford to be spending the money, then find that we need to go begging for more money. But at the same time, there is not a limitless budget and this needs to be cost effective. So comments like "you can get away with xxx, but could improve things adding an extra flash at a later date to cover xxx, and it will work with everything you already have" would be great.
Ok... that's it... I open the floor to you guys for comments, suggestions, and some much needed advice. Thanks
