- Amin
Can someone help me please.
I have just received the wireless remote ST-E2 bought here from a fellow member, although I do not have the manual for it the settings look straightforward. The only problem I have is that when I attach the remote on the hotshoe all I get in the menu for EXTERNAL FLASH CUNC SETTING in the camera are the EXP. COMP and E-TTLII. The rest everything is greyed. If for example I want to change to Manula in the FLASH MODE instead of E-TTL, or alter the shutter sync all these settings are gryed and I cannot access it.
Can someone please tell me how do I get around this and get the meny to function properly?
I am sure this transmitter should allow me to alter anything else instead of forcing me to shoot in ETTL mode. Even the High Sync is not possible to be used this way.
Can someone please help me with any resolution for this?
I have put the 580EXII in slave mode, tried every single setting I could think of but failed so far. Am starting to get frustrated as I was hoping to use this remote tomorrow.
Many thanks
Amin
Many thanks
Amin
