- Mark
Decided to clear out some old unused togging bits and bobs taking up space recently.
One was a Coco ringflash adapter, abandoned a while back for it's limitations. It had the issue of being too harsh in it's lighting, and left images looking a bit flat. Main issue was that it was very big an bulky, and wouldn't let you get low enough as the botoom of the 'ring' extended a few inches below the lens.
As it was damaged, and subsequently held together with duct tape, I was going to chuck it away, but had a brief thought about maybe extending it's use a bit. So I chopped off the bottom half of the ring with a hacksaw, covered the ends up, and stuck it on the camera to see what it could do with the MP-E65
... by markhortonphotography, on Flickr
This was effectively at a little over 1:1. My MP-E has the 12mm tube on it, pretty much at all times. Sadly the ring flash won't reach the subject when extended very far, so this 'experiment' is really only a frivolous exercise. I quite like the semi circular highlights in the eyes though
It does work with the Raynox202 on the lens which ups the magnification to acceptable levels, but it's not the most flexible of options.
peekaboo ii by markhortonphotography, on Flickr
peekaboo i by markhortonphotography, on Flickr
Fun experiment which has probably extended the Coco's usefulness a little bit, but I still need a solution to easily keep the flash over the end of the MP-E65 as you extend and retract it through it's full length, which I don't see being possible without a 270ex type flash, which is not a possibility at the moment.
