A little help required....
Dave
...sorry if this has been answered before, but I cannot find it anywhere. I am doing another wedding on Saturday, with a 7D and a 40D. Is there any way I can load all the RAW's into a folder, and somehow sort them in time order so the images go in sequence from both cameras?? Obviously I will make sure they are both set to the correct date \ time.
I use W7 with Elements 7 and CS5
if you put the images into one folder, then click the date taken it will put then into the right order for you, i dont know if this will keep them in that order but it might.
if you have adobe Bridge that my do it also
Cheers Steve
Its a problem I havn't fully worked out yet. File nameing will be all over the place but you can sort by time taken then rename everything. But for it to work you times need to be synced exactly on each camera.
When transfering to the PC use the rename function in canon DPP so that you can store all files in a single folder which will make you able to rename everything in a single go.
Cheers Steve
Sync your cameras timewise
Edit crossed post with Little John
Cheers Steve
Thanks Guys!!! Didnt know if explorer could do it so thought I would ask!
Will do a test run before the big day just to confirm!
You have CS5 and Bridge will definitely do the job
Cracking thank you. Never ever needed to do this so had no idea it could do it :lol:
Thanks :thumbs:
