AA 2700 mah battery charger
Frank Wilson
I've have 2 dozen 2700 mah Rechargeable batteries which don't seem to charge fuly in the charger I currently use.
Anyone know of a decent charger, preferably one that'll do 8 or 12 at a time and fully charge them.
I find my 2700mAh batteries take about 24 hours or so to charge properly in a regular charger, so I've ordered a couple of one hour (4 cell) fast chargers (£24/pair, delivered). I'm sure there are lots of reasons not to use these, but I've got as many batteries as you and only 2 4-battery chargers so it's a fulltime operation keeping them chargered.
They're sitting at the post office awaiting pickup so I'll know on Monday if they are any good.....
or a Powerex MAHA charger/analyser.
Yup. I bought one of these after a similar experience with a Uniross charger that took several goes to get a full charge. Takes a while to power a heavily discharged set of Eneloops, but worth the wait. Had a bit of a 'mare finding one in the UK a while back. Not sure if that's any easier now.
+1 for PowerEx - you can buy the charger here
A lot of the chargers simply use a timer system to control the charge to the batteries , they don't rely on the charge current/voltage to indicate when a set of batteries is fully charged. This method was fine when the highest power you could get was about 1800mAh.
The newer high power batteries need more, so I tend to charge them twice. This seems to work fine if just taking longer
Memo to self: Must but a better charger sometime
Check HERE.
Or HERE
I have the digispeed 4 great fast charger, comes with home and car power supply plug, plus it alerts when duff battery is inserted.
Dave
+1 Ansmann chargers. I had a Uniross and as others have said they just use a timer which is not very good for your batteries. Ansmann chargers detect the drop in voltage that happens just before a NiMh battery is fully charged then drop to a trickle charge to finish off the charge.
My rechargable batteries last about 4 times longer now because they are charged properly. It will be a little more expensive to start with but you will get that money back with 2 sets of 4 batteries life cycle.
Choccy...
