AA Battery Advice For Flashguns
gerry
Looking to get some AA rechargeable battery`s for my flash guns looking at Eneloop or Duracell
any opinions what to got for? Also looking at the Maplin charger as well .
Or is there any other make I should consider ?
Cheers Gerry
Hi there I used Eneloop for many years when I was doing weddings in the EX580 and they were excellent.
Charger wise I used a Maplin fast charger again no issues.
+1 for Eneloop. Bought a couple of Sanyo chargers (NC-MON04B). They take about 10 hours to fully charge a set of 1,900mAh AA's.
cheers for that there a white and blue and green ones what are the best ones
Gerry
I have the original white and blue ones.
I've got the 1,900mAh capacity white and blue ones. They work just fine. The higher capacity Eneloop Pro's (2,450mAh) cost a fair bit more. Didn't seem worth it to me.
Older Eneloops are the Sanyo ones afaik as they were bought out by Panasonic. Might not be any different but I went with the Panasonic ones.
I think the higher capacity Eneloops don't last as long either so it's only worth it if you really need the extra power (the regular ones seem to last a decent amount of time with a good charge).
+1 on the smart charger, even a high quality battery like eneloops can get out of sync with the others in your set, a charger like the one above that charges each cell individually and allows for refresh cycling will keep them all at their peak performance.
