Annoying problem, please help! ( newbie )
Adam
Hi guys.
I'm new to DSLR's.
I've got a Canon EOS 20D and have a bit of a problem.
I have been farting about with different things - exposure/iso/shutter speeds etc, but i've done something so that the camera won't AUTO FOCUS on P mode....
I'm stumped... it auto focus's on other modes but not P mode..
Please save me!
Sounds weird.. Could you give details...
Does it attempt to autofocus and fail?
Are you sure AF/MF switch on your lens is in AF position?
Are you sure AF points are set correctly? But then again in P mode AF points should be in auto mode, at least on newer models, not sure about 20D.
Hi folks.
THanks for the replies.
I checked the switch and it's definitely on AF.
I finally managed to sort the issue, however. I went into the settings and choose " reset all custom functions " and that sorted the problem. I'd obviously just messed up a setting when i was faffing about lol..
Feel so dumb!
Thanks again for the help.
You have probably used a Cf which moves AF function to the back button. Just a guess, though
It took me few seconds to work out that you meant Custom Function and not Compact Flash :bang:
