Anyone using Delkin Sensor Scope System
Ben
Need to clean the sensor on my 5d checked out the Delkin Sensor Scope System which sounds ok .. anyone use one? ... tried my rocket blower but hasen't moved the spots :'(
thanks in advance
thanks in advance
I've got the Sensor Loupe, which is similar - magnifying lens with illuminating leds. Best cleaning accessory I've bought.
Yep, I'd recommend the Sensor Loupe as well..really gives a clear look of the sensor. I believe it's brighter than the Delkin
well got the dust aid coming
the sensor loupe does look like a great accessory ... just added to shopping list
when taking the test images which are the best camera settings?
Close focus, as small an aperture as you can get and against a reasonably well lit uniformly (pale) coloured backround. Use Aperture priority and let the camera chose the shutter speed. Camera shake doesn't matter since what you're looking for is stuck to the sensor!
If the area isn't uniform, move the camera around as the image exposes, this way you end up with a non-descript image, easy to spot the dust spots :-D
