Battery help LP E4
Hi guys
Ive just had a battery go on me on my 1D IV today, no power at all from it even after charging its just getting hot. No idea whats happened too it, stored beside my second battery so who knows.
Where can I get replacement LP E4 batteries? LP-E4N are of no use as you need the correct charger for it.
Is this a genuine Canon battery?
The older LC-E4 will charge the LP-E4N
Can be charged in older LC-E4 charger, but be aware of the following:
If an LP-E4N battery pack that has been charged and discharged many times is charged- up in the LC-E4 charger, all three of its charge indicator LEDs may blink repeatedly, which indicates a battery malfunction. If this occurs, press the Calibrate/Performance button on the charger, which changes the three LEDs to temporarily indicate a battery’s recharge performance level — in other words, its ability to take and hold a charge. If one or more LEDs display without blinking as the button is pressed, the battery is still OK.
From Canon here... http://www.learn.usa.canon.com/resources/articles/2013/lp-e4n_battery_pack.htmlp
Bob
Ah right so it won't explode into 1000 pieces then, thats good to know. Thanks for that Bob.
