- Keith
With so many makes and models out there I get confuzzled when I try to research tripods. I want a sturdy, but not so heavy, tripod + ball head with levers type. I like the kind that have that soft foam on the legs. I had a mediocre manfrotto up until recently but it's max load capacity was 3.5KG - apparently. It seemed to struggle a little with just over 2KG, when tightened up it would dip slightly once you let go of the camera/lens.
I guess I'll want something that claims to hold 5KG+ - but doesn't weigh anything close to that itself. A flexible mid column might be handy too.
Suggestions? I might go a little higher if it's really worth it.
