- Simon
Had this problem today at a baby group shoot.
Basically the first few shots were ok (all images here are untouched RAWs and just to show the issue). SS was 1/160 or 1/1200 from memory and aperture was f8-f10. On a D300 with 24-70.
Test-1 by snowens, on Flickr
After a few shots I noticed this black 'spot' between lip and nose
Test-2 by snowens, on Flickr
It seemed to be that the first few shots were ok, then it happened. Luckily had backup (D700) so put the 24-70 on that and all was fine. Went back to D300 and put on my 50mm. I machine gunned it a bit and the first few shots were ok but then it happened again. I changed to f3.5 and machine gunned and all looked fine.
Test-3 by snowens, on Flickr
So went back to f10, and first couple ok
Test-4 by snowens, on Flickr
Then if you look at the windscreen...
Test-5 by snowens, on Flickr
So, it didn't happen on the D700 so can't be the lens (and on D300 it happened with both lenses) - Happened at various backgrounds. Seemed to be ok at the start but then happened.
Only thing I can see is that at wider apertures its not an issue? Last use was a few weeks ago at Duxford shooting planes - never had an issue before so can't be 'sun damage'?
Ideas welcome!
Test-1 by snowens, on FlickrAfter a few shots I noticed this black 'spot' between lip and nose
Test-2 by snowens, on FlickrIt seemed to be that the first few shots were ok, then it happened. Luckily had backup (D700) so put the 24-70 on that and all was fine. Went back to D300 and put on my 50mm. I machine gunned it a bit and the first few shots were ok but then it happened again. I changed to f3.5 and machine gunned and all looked fine.
Test-3 by snowens, on FlickrSo went back to f10, and first couple ok
Test-4 by snowens, on FlickrThen if you look at the windscreen...
Test-5 by snowens, on FlickrSo, it didn't happen on the D700 so can't be the lens (and on D300 it happened with both lenses) - Happened at various backgrounds. Seemed to be ok at the start but then happened.
Ideas welcome!
