- Steve
Finally, finally got my 1D Mk3 tonight and all kinds of problems, one of which is sorted: bought from the States via Kerso, the externally supplied UK adapter only had a 1 amp fuse which popped as soon as I put it on the mains adapter and plugged it into the battery socket on the camera.
Bought a new UK travel adapter and the camera works OK with the mains adapter.
The problem I am left with is that although the battery charger lights up and appears to be charging, after 2 hours I tried the battery in the camera and it only lasted 10 minutes.
Put it back on charge and the three green lights flash in 5 second intervals then show 80% charged. When I hold the display button down, it indicates the battery is 100% charged.
When inserted in the camera, as dead as a dodo and no short red light on the camera as it is inserted.
I don't know if it is a duff battery or a problem with the charger.
I don't get any red lights on the charger indicating the need for calibration.
My question to 1d Mk3 owners is, should all three lights be be going out for a second in 5 second intervals when charging?
The manual says something about the battery being out of it's temperature operating range when this happens.
Do I have a duff battery or a duff charger?
It's not like I can go and pick a battery up from Tesco for a couple of quid to verify it.
