d90 battery problem
garry
i bought a brand new d90 in november,i will be lucky if i have taken 500 photos,when i charge the battery it is only charging to 75% and running down quickly,i have just had a look at the battery info in the camera and it is showing 4 which means the battery is at the end of its charging life,the battery has been removed from the camera when not in use,has anyone had the same problem,surely a battery should last longer than this.
Definitely should be much better than that. Got my d90 In October last year and it's still showing zero in the battery age gauge. Must be a fault with your battery I'd say.
Is it a genuine nikon battery or a 3rd party battery. Where did you get it?
Sounds broken... I've got genuine and aftermarket batts that have all been well used, and they still show zero on battery age.
Take it back to the shop?
