- Kev
I have had my 2014 Ford Fiesta from new and have had no problems with the battery until today. I have even left it for 2 weeks while on holiday and it has started fine. Today however the battery was completely drained, I measured 4.7 volts across the terminals, it had last been used on Monday evening with no problems.
I called out Ford assistance and an AA van arrived in 15 mins, he got the car started and waited a while then I switched off and started again OK. He told me that there is a problem with Fiestas draining the battery and that Ford are having to change some software to prevent this. The short term fix is to leave the audio unit switched on when turning off the ignition as if the audio unit switched off something keeps signalling something else (Note the technical terms
) and drains the battery.
This seems wierd to me but on Monday I did have the audio unit switched off which is not usual, it is normally left on all the time. I have had a look on the internet and the problem is mentioned a couple of times, someone has said it is the bluetooth trying to link to a phone all the time. The AA mechanic suggested that I contact my Ford dealer and see what they say.
Has anyone else come across this problem and if so did they solve it?
