Bit of an experiment. Sprayed a CD with a water sprayer (thankfully a brand new dirt cheapy CD, as the water sprayer had vinegar in it )... Used the Raynox on the 55-250 again
Thanks for the comments. I gotcha, back to the drawing board... There must be some trick Simon, but I don't know what it is. I guess getting directly overhead, no angles to minimise the effects of the short DOF :shrug:
hi John
good but no cigar. Not sharp enough mate
on my 450 i use the live view x10 on a macro rail mirror lock up and remote cable plus 2 sec timer to get the focus sharper. still doesn't work though
John eosjohn got a macro rail off ebay from HK £26 I think this is it , Clicky Linky its solid well made, I was surprized at the quality of it for a cheapy
hi John
Make sure you're not moving around on the floor that the tripod is on too. Although I just use the viewfinder rather than faff about with liveview and sometimes use a 2nd press of the remote release to fire the shutter rather than the 2 second timer depending on what I'm doing.
For high magnification work there's a chance that pressing buttons to operate liveview or change settings will mess up the focus.....once you've got focus don't touch anything.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
