- Toby
Yeah I appreciate that knowledge and experience is key, my comment about not liking rubbish equipment is not because I don't think it will give the results, but that it's such a pain to use that it takes the fun away.Yes, that kit is rubbish. But, if you failed miserably with a particular shot, then the failure will be much more down to lack of knowledge to lack of equipment, knowledge (and care) trumps equipment every time, and people who have the benefit of knowledge can usually manage with limited equipment - it just takes them longer than if they had the right stuff, and there are some shots where equipment is more important than others. Any lighting equipment though, regardless of build quality, light quality, colour rendition index, colour temperature or anything else, does need to be capable of being used with light shaping tools, and also needs to be capable of a fairly wide range of adjustment.
Thanks, interesting.OK, I just said that knowledge trumps gear, and it does - but the cheap flashes are just as bad as the cheap continuous lighting. Umbrellas are often under-appreciated, they can be incredibly useful for a lot of shoots, but they can also be a very bad choice for product-style shoots, it's pretty impossibile when the light source itself isn't flat, and is also unevenly lit - there's no point in making life hard for yourself by using tools that cannot produce the results you want. Generally, with softboxes you get exactly what you pay for, and there is a reason why some are dirt cheap.
My space is very limited and it's extremely difficult to get the subject any distance away from other things in the room so they still end up getting lit no matter how I angle the light. I just a black towel for those camera shots and a bit of PP for the bits that still showed up.Do you actually need a backdrop? Portraits, which at the moment you don't do, often do need something, but what you're talking about here is creative still life work, where everything is entirely under your control. Usually, a plain wall is all you need, at most. At the moment my studio is 3700 sq ft (it will be bigger soon) and I could put up a lot of different backdrops but I hardly ever do, I just use either a white or a grey one and, depending on the lighting, it will end up anywhere from pure white to pure black, or in any colour of my choice. If no light reaches the background, it will always end up black.
Now that you said that, that's what I was told before tbh. It wasn't the power per se as I'd said before, but the light distribution. I made the leap that it was lack of power that meant it couldn't fill the softbox evenlyIt isn't about having enough power, it's all about hotshoe flashguns having a fixed reflector that doesn't distribute the light around the softbox, which means that the illumination is very uneven and that the size of the softbox is extremely restricted.
ThanksYou did well with those shots. LED lighting is usable with shots that basically don't include colour, and where any colour that is there doesn't need to be rendered accurately. But, when you start using studio flash, it will be light a breath of fresh air![]()
