Gossen Sixtomat Flash question/problems?
Hi, firstly, does anyone have one of these? I bought one a while back off and have never seemed to get the hang of it.
Ive been through the manual and a couple of times when i have used it in anger it has actually worked as i expected. This is with my complete lack of knowledge other than a couple of youtube videos on a similar model.
I tried to use it the other day and it came up with a message En which suggests i need to press the down arrow to correct the reading. The problem is, i can't get it to apparently change anything?
Is it goosed or is it operator error, because at the moment i cannot seem to take any measurements what so ever. All the proper manuals/tutorials seem to be in german.
Thank you.
Thank you.
The following link should help you.(y)
http://www.gossen-photo.de/pdf/ba_sixtoflash_gb.pdf
George.
If all else fails then take the battery out, should reset itself, works with my Variosix F, although the reading suggests its too bright.
