- Mark
Hi all
Hope someone can help.. Im using a 5d mk2 & 580ex2 flash. Deciding to get some off camera action i went for the yongnuo st-e2.. Now i dont know if this is a fault or if the yongnuo doesn't support "manual flash control" from the camera lcd panel.. With the canon st-e2 in the flash function settings menu there is an option to select ettl flash mode or manual. Selecting manual reveals a futher option where the power output of the flash can be manually altered rather than resorting to going to the flash to change power manually.. Selecting manual with the yongnuo attached simply flips it back to ettl... Has anyone experienced this..? Is this correct or is it a dodgy unit..?
Mark
Mark
