Mr Bump
From under the bridge
- Sophia aka Paul
I have a Bosch 18v Cordless Circular Saw it came with the blade Bosch 2 608 844 565
it has worn out so i want another
I can't find one for sale, any thoughts if it has been superseded?
AI Overview
The Bosch 2 608 844 565 is an
Eco for Wood circular saw blade designed for handheld and corded circular saws. It is specifically designed to provide clean and fast cuts in all types of wood and wood-based materials.
Key Specifications & Features:
Bosch Professional 18V System Cordless Circular Saw GKS 18V-51 (Brushless Motor, incl. 1x Saw Blade (140mm)
AI Overview
- Dimensions: 140 mm Outer Diameter, 20 mm Bore Diameter
- Kerf/Thickness: 1.8 mm / 1.1 mm (Extra-thin)
- Teeth: 30 Teeth
- Blade Material: High-quality steel with carbide tips
- Application: Ideal for general woodworking, providing a balance between speed and quality of cut.
