Help with speedbooster for M43 and old M39 lens
patrick
Hey guys,
I'm a new member, first time poster and relatively new to photography, so please forgive if this is obvious.
So I'm a micro 4/3 user with a Panasonic G80 and I use exclusively vintage lenses (as we all know, Panasonic don't do autofocus anyway, so why not go full manual :D )
I use old M42 lenses, primarily Helios 44 58mm and Mir 1B 37mm. Recently added a Carl Zeiss Jena Tevidon 10mm to add to the collection along with a Viltrox 0.71x focal reducer to try and obtain closer the true focal length of the lenses taking into account the M43 crop and to make the lenses more versatile.
The Helios & Mir lenses are fine with the Viltrox speedbooster, no problem whatsoever. However, attaching the Zeiss Tevidon lens (M39 mount) to the speedbooster, just gives a blown-out image of light, totally unusable. But it's fine attaching straight to the camera with a M39-M4/3 adapter.
I can't figure out what exactly the problem would be. The M39 adapter to M42 fits fine and that attaches perfectly onto the speed booster, so I'm tearing my hair out over why I don't get an image.
Many thanks for any help anyone can provide :)
Patrick
No idea but it could be that the camera is greatly over exposing the picture for some reason. Maybe you can get some clues by looking to see if the lens aperture is operating when fitted to the adapter and what the shutter speed and ISO are doing? It could be that the lens isn't stopping down whilst mounted to the adapter whilst too low a shutter speed or too high an ISO is selected?
Also, I assume you are in either aperture priority or manual?
I use manual lenses quite a lot and have only once had a metering issue which quickly disappeared and I couldn't reproduce it but looking at the aperture blades and the shutter and ISO setting should hopefully give you some clues.
My main tip would be to use auto I.s.o it takes one side of the equation triangle out . You then only have shutter speed and aperture to worry about .
