- Mark
Hi all,
I've built myself a new computer and am running 2 screens. I have an LG 22" monitor and also a 17" Dell monitor both run off a Radeon HD 6750 graphics card on windows 7.
The problem I have is that the LG 22" screen doesn't display in full size when using the HDMI cable. I've set it to the recommended resolution and it leaves a gap of around an inch either side of the displayed image and around half an inch top and bottom. If I switch to use the DVI-D cable it displays full screen?
Normally this wouldn't be an issue as I'd just use the DVI-D cable, however I use this port to run the other monitor. I can get the LG to go full screen with the HDMI cable, but I need to run it at a lower resolution and then it doesn't display perfectly.
Has anyone got any idea's on how to get the picture to the correct size when using the HDMI cable and set at the optimum resolution?
p.s. I have installed all of the latest drivers for the motherboard, graphics card and monitor.
Many thanks
Mark.
Many thanks
Mark.
