- Jamie
I received the Hahnel Giga T Pro today and have to say I'm quite impressed with it apart from one issue; it doesn't appear to work in high speed continuous. It has a continuous function built into the device which seems to run at around 1fps but doesn't make use of the 5fps my D200 is capable of. Now when it's plugged in directly and used as a wired remote it fires off in whatever setting the camera is in and can do 5fps. Is this standard behaviour of wireless shutter releases or a limitation of this particular device? Am I doing something wrong in setting it up? When reading up about it I'd read that it was capable of continuous shooting but this was clearly in reference to a feature within the device.
Edit: Can anyone recommend an alternative radio shutter release device that is capable of using the high speed continuous device. I've seen that phottix do a model but the build quality looks a bit poorer (price is much lower than the Hahnel) and probably won't stand up to the weather all that well so I'm looking for something with a little higher build quality.
