Need a bit of help with my T70
Hi all, new to the site and wondering if someone could help me out a bit. I've always use digital cameras, but changing circumstances have led me to sell my beloved 30D and lenses, and eventually I settled on an old T70 film SLR to replace it - for less than £40 including a 50mm 1.8 I didn't think I could go far wrong.
And so far so good - it's all in great condition and perfect working order, but I'm struggling a little bit with the interface. The online Canon manual is hopelessly inadequate so I'm trying to learn as I go along. The problem is that 99% of the time I used to shoot in Aperture Priority, but now that's no longer an option I'm trying to get to used to manual mode on the T70. And here's the really specific question:
Manual mode, it seems, is selected by putting the camera in Tv then taking the aperture ring off A and turning it to the desired setting. Only when the camera detects there is too much light it displays a smaller aperture in the display anyway - so if it's going to override my selection, exactly what is the difference between Tv and Manual mode? Hope someone can shed some light on this - I'm really quite enthusiastic about the new camera but could use somebody helpful for guidance!
Jonty
Found and had a look at the manual.
Ok, you have it correctly set for manual, but when it shows an aperture in the view finder "that is the one it is recommending you to use for the conditions you are photographing"
As an example you have set a shutter speed of 1/125 and moved the lens ring to say f8, and it will happily take pictures all day at those settings.
HOWEVER in the view finder it might be saying 'f16', that is what it is recommending you select for the correct exposure.
It might be showing you a smaller aperature but it will not override what you have set.
You could always stick the lens back to 'A' and the Mode to 'Tv' which is now 'shutter priorty', so you pick the speed the camera selects the aperature.
Hi there, thanks for the reply. After I posted I had another look at the manual and realised where I was going wrong - I'm used to the viewfinder displaying the aperture I have set, not what it's recommending for me. Thanks for taking the time to clear that up for me! :)
