Need help choosing a lens for a friends wife!
John
Hi,
A friend of mine has posed this question - "What should I get for my wife?"
Dangerous territory or what!
Anyway from the discussion we seem to be talking about a longer zoom, she already has the Canon 18-55 kit lens on a 500D which isn't too bad.
He did cloud things by saying she might want to do landscapes but the 18-55 will do that fine.
Anyway the budget is £200, initially I thought the 55-250 as it fits with the range and if I recall isn't a bad lens either (I used to own one years ago, but moved to the 70-200 then 150-500 and finally back to the 100-400 so it seems like an age ago and my memory is clouded).
Third party isn't ruled out, nor I suspect is second hand (but I would need to double check that).
I'm going to ask this on a Canon specific forum too, so don't be startled if I suddenly jump in with some oddball questions!
Cheers,
John
Oh, I just realised she mentioned that she likes macro too, so I wonder if there is an option that would work with that too?
Well you can get Canon macro lenses, like 100mm or 180mm but the problem is they are prime lenses and a bit expensive.
I think you can get the normal 100mm one for about £450 new (im saying normal because there is an L version too) not sure about second hand.
Good luck anyway
Sadly way over budget and as she only has the 18-55 at the mo I would have thought a better choice would be a decent range zoom rather than being restricted to primes, possibly the 55-250 or the Sigma 70-300mm f/4-5.6 APO DG MACRO if thats any good.
If she likes macro then a reversing adaptor for the kit lens (about £10 online) would be good then get the longer zoom. I would personally go with the Canon 55-250 over the Sigma, if the extra reach was desired I would go with the Tamron rather than the Sigma (I've had both in the past) and the Tamron did a bit better.
What should he get for his wife?
Depends on her spec, mileage and condition...
