Neewer Macro LED Ring Flash RF550D
wayne clarke
My other half has got right into macro since getting a sigma 50mm macro. She's spotted these led ring lights Neewer and the Meike similar version.
Does anybody actually have one of these? Are they any good for boosting light for close up? Any advice welcome.
Well, at extremely close distances they're bound to boost the light to some degree, especially if the shutter speed can be fairly slow.
But it's extremely deceptive to describe them as "flash" when they're not, she would obviously be better off with a real flash one.
All Neewer products are "similar" to something else - that's because they don't make anything themselves, they re-brand.
They do sort of have a flash setting... well the led's just light up during the exposure ;) although how you'd get a proper exposure is another matter as it's not talking to the camera.
My other halfs not that keen on flash, I've even given her one of our spares but she just can't seem to get on with it. It's the continous aspect she likes. It'll be great for video she says, well it would be if she did any video.....
Thanks for the reply Garry.
A basic flashgun and a little bit of DIY and this is what you get which works as well as anything
EM1 sigma 105 Mk11 by Alf Branch, on Flickr
Funnily enough I saw a similar version made from card and velcro the other day. It was lined with silver metal tape (which I have knocking about) I might well knock up a version similar to this. What are you using to diffuse the light at the front? I'm thnking a cheap ebay softbox front cut to size should work??
A Pringles tube also works well .. quite a few ideas on youtube
There are lots of eaxamples here https://www.talkphotography.co.uk/threads/show-us-your-macro-rig.132158/
The one posted is a pringle tube (silver lined) and a plastic takeaway container with some polystyrene sheet and duck tape
Macro-rig-2 by Alf Branch, on Flickr
That an old Macro lens Alf - The latest one does not extend and I find that a huge bonus
I use a ring flash on some occasions - made by Godox or my Nissin Di700 with a white card reflector
Les :)
Les :)
That is a 4/3 fit lens which is easier to get to work on m4/3 than many others
Alf whats the ring with button on the front of your macro lens? It's not in the first pic. I'm guessing some sort of extra close up. With the tubes and the lens you must be getting way about 1/1. How far up can you go with that set-up?
Thats a Raynox macro attachment to give more magnification, the "button" is a release catch to take it off the lens.
The set up shown is my Olympus E-M1 with a 4/3 Sigma 105 f2.8 DG macro lens a set of three (cheap plastic) tubes that failed with this weight and Raynox DCR 250 there is a 44/3 to m4/3 converter
http://www.raynox.co.jp/english/dcr/dcr250/indexdcr250eg.htm
The lens provide 1:1 but with the tubes and Raynox I would get 2.9:1 magnification
Looking like this uncropped shot
105-mag-test-tubes&R by Alf Branch, on Flickr
Here is a side view
Macro-rig by Alf Branch, on Flickr
Here is as shot with the lens only
Sigma-105-mag-test by Alf Branch, on Flickr
Here is a shot with that set up with a measurement across the frame of 8mm using a single 25mm extension tube instead of the three cheep ones
Collembola in 8mm frame by Alf Branch, on Flickr
The 48 LED thing?
At 12" it's worth about 3.5 stops, but if you use the diffusion that drops to about 2 stops. For closeup and the ringlight look I would say it's worth a go given the price.
Here is a side view
Nice shot Alf. 2.9:1 blimey you must be best mates with the bugs. ;) When you see some of these things close up they look really alien.
The 48 LED thing?
Thats what I was thinking, it's cheap as chips on flebay. I might just order one and have a punt for £20.
I think I have one in the cupboard that I never bothered with so still as new.
you can have it for the cost of postage if you want.
if he doesn't want it I'll take it please
A shot with Peters ringlight (used over the top not on camera) the "conker" spider. The light from the ringlight is quite bright and really helps a lot. The colour is a very good daylight match.
Some fungi, the ringlight is pretty much the only lighting here it was more or less dark. Light off to one side.
I got the cheaper version but not really for the flash (which didn't work well with my camera) but for the constant light setting. It is heavy on batteries so I added a dummy battery system to run of the mains as my close up work is all at home. Neweer do another version for around £65 which is supposed to be TTL compatible. All my close up work is on small, fairly flat items shot with 10x close up lens to fill the frame. Works for me.
I've heard mixed reports of the proper flash version, it seems theres an issue with one side dying from what I'm hearing.
To be fair the Neewer led one works fine for the sort of stuff I play with, mostly fungi or flowers, and if I can find them dragonflies/butterflies (had a good year last year) I haven't noticed any battery issues yet, that said it's only for a few mins at a time with me.
