- Jan
Anyone come across anything like this? I have an HP laptop about 2 1/2 years old - a small one (something like a 10" screen) with a sealed in battery. Recently it's been having some strange issues where it seems to think the battery is flat, but it isn't. This morning was fairly typical. It was charged yesterday and hadn't been used till this morning, so the battery showed 100% charged. Within a few minutes the screen dimmed and the battery indicator showed 16%. I did a restart as this can often reset it, and got the 'battery dead' message during boot up. Cancel that, boot up anyway, and half way through the screen goes off. I did another restart by pushing and holding the power button. This time it started up but the light next to the power socket started flashing white, and the battery indicator on the task bar had the red cross for dead. I plugged in the power lead, plugged it in to the mains and within a few seconds the steady white fully charged light came on, so I unplugged the lead and now the battery is showing 100%. I wondered at first if it was a heat thing as I had it happen a few times when the laptop was charging but on my knee, where it does get a bit warm, but I don't think that was a factor this morning. It'll probably be fine for a couple of weeks now before it does it again. Unless it is a heat issue, it seems more of a software than a hardware problem as the battery clearly is not dead. Any ideas?
