I haven't got that version but usually you would add a new blank layer and then add a white to transparent gradient across it. (the new layer gives you the advantage of moving the gradient or altering the opacity after) Wayne
I'd suggest using a layer on top of your image that's quite white. If you delete a circular selection from that layer and blur the whole layer afterwards, you should get what you need.
EDIT: swanseamale47 beat me to it, it's another way of doing it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
