Problem with my Canon EOS 400D not focusing in Sports Mode... help!
Hello
I'm new to this forum but desperate for advice!
Basically, I have a Canon EOS 400D which for a few years now has worked perfectly (apart from the memory card jamming inside and some parts then falling out of the compartment... but that's a whole 'nother story!)
A while ago I found that when I shoot in Sports mode (which with a toddler about, I do quite a bit) the red lights that show where it's focusing do not light up and I can't shoot. So frustrating!
I've tried contacting Canon and they suggested resetting the factory settings which has not worked.
Has anyone got any other suggestions?
It's not out of the question that I am being extremely thick and have left on/turned off some function, or slid some switch somewhere along the line but I'm so keen to get out and take more photos but feel really stuck without Sports Mode working.
Many thanks for reading this; I really hope someone can help!
Claire
MF/AF switch on the lens?
Does anything work in any other modes?
Is the lens properly connected to the camera?
Oh, and welcome to the forum. :D
Hello tdodd, thanks for your fast reply!
In answer...
set to AF
macro, landscape and portrait all focus (beeps and red lights) fine
checked the lens, it's on correctly too
so puzzling, and I just can't afford it to be an expensive repair job (can't believe it is really!)
Cheers, Claire
Hang on, I'm not familiar with your specific camera, and I don't use the "Basic" modes myself, but in Sports mode I'm pretty sure the camera will be using AI Servo focusing, which certainly will not beep. I would expect the active focus point to light up briefly, when you first press the shutter button to initiate AF, but then to go out and stay out while you continue to follow your subject. That would be normal behaviour, I think. Does the AF point (any of them) not light up even briefly?
The thing with sports mode and AI Servo AF is that it expects your subject to be moving (sports tend to involve movement, unless you're talking snooker) and so the AF will track continuously. It never actually locks because it is always searching for movement to readjust. One beep initially would not be helpful for the remainder of your shooting and you really would not want it beeping continuosly. Therefore, by design, it does not beep at all. I would think you would get a brief blip in the viewfinder though, just to remind you of which AF point was active/selected.
Oh, and you should also be aware that if you have all AF points active, which probably the default and possibly cannot be changed in Sports mode, the camera will always commence AF with whatever is beneath the centre AF point. (Actually, maybe that's why nothing lights up - if it does always start with the centre point.) If the camera detects that the subject has moved elsewhere in the frame then it will hand over AF responsibility to one of the other AF points now covering the subject. That's the theory. Practice may work out to be a little different. It depends on how large your subject is and how clearly it can be distinguidhed from the surroundings by the camera.
I too thought that the AI Servo should be working, as the manual explained that.
But on the LCD, the 'AI SERVO' is light grey, instead of the active black font to show it's selected. IS there a way I can turn it on I wonder?
I'm still a little confused as to what my camera is managing, as I took some trial shots of my OH walking around, to test it. It did beep (but not red light) as if it was focusing each time. Some shots are coming up sharp, others are still blurred (however dim lighting could be to blame here).
Thanks so much for your help and suggestions, tdodd!
Claire
In the "Basic" modes, like Sports, Portrait, Macro, Landscape etc. the camera sets several options for you and locks them to what it thinks is the wisest choice. So, for example, if shooting sports it will not let you switch out of AI Servo AF.
If you want more control of things then you need to start using settings in the "Creative" zone, such as P, Av, Tv and M. Then you get to choose all sorts of options and set them just as you wish. You'll probably find that new menu options become available too, such as shooting to raw instead of JPEG. You'll also get to choose the AF mode and even which AF point to use.
Sorry, only the first paragraph of your last post came through. I've now read the 2nd and 3rd and think the best thing will be to wait till tomorrow's daylight and wait until our toddler/cat/chickens are pegging it around. Then I'll have a good chance to see just what is going on. Like you suggest, I could just be misunderstanding the settings. Let's hope so! (although that is a bit humiliating!...)
Many thanks!
