- john
Hi,
I don't really do much flash work, so I bought the yn467 flash and used on the D5000, no problem.
But the flash locks up if I press the test button, or switch it into any of the slave modes( one flash and it locks, have to switch off and back on )
Now this was fine on the D5000, but now Im using a D7000 and I would like to use the slave modes.
Has anyone else have problems with this flash, or can suggest a fix.
The unit was bought from HK and it is to much a problem to attempt to return for fixing as it does work in I-ttl and manual.
