- Christian
Does anyone know if the Rolleicords can be a bit fussy about the positioning of the shutter speed lever?
Just been messing around with my Rolleicord IV with no film in. I opened up the back and pointed the camera at a light source to see if the shutter seemed to opening correctly.
I *think* it was ok at 1 sec but it seemed slow at 1/2 sec and 1/5th sec. I then went to B and it seemed fine. When I moved it to 1 sec again it closed as soon as I let go of the shutter lever as if it was set a B still but when I moved the shutter speed lever a tiny bit further past the 1 sec marker it fired at what seemed like 1 sec. It was the same thing at 1/2 sec. Line it up exactly with the 1/2nd sec marker it still seemed to be opening for 1 sec but moved it a tiny bit further and it definitely opened for a shorter time. I'd not taken any shots below 1/25th but even so it could explain some apparently random overexposures :shrug:
