- Andrew
Hi guys. I've just purchased a Dell U2725QE Thunderbolt 4 27" monitor for my upstairs Mac Book Pro (16" M1 Max version), but I've having a few difficulties with a specific problem that I'm hoping someone could assist with.
So, I have my 2.5Gbe ethernet cable plugged into the Monitor, and then the Monitor is plugged into the MBP via the thunderbolt 4 Upstream socket directly into one of the MPB's Thunderbolt ports (so effectively I'm accessing internet over the Thunderbolt cable). So far so good, the picture is beautiful, ethernet works as expected. However, I have an 8TB Thunderbolt NVME external enclosure also plugged into the MPB. I'm trying to back up a very large amount of data from my NAS (located in my study downstairs (and also on 2.5Gbe), I can see the NAS on the MBP, and I start copying the files.
As the transfer process will take several hours, I then put the monitor into standby mode, and within 10-20 seconds the light on the external drive stops flashing, and on examination it seems that when I turn the monitor off, it seems to be cutting the ethernet to the MPB, and so it both stops transfer and obviously loses connection to the NAS downstairs. According to Dell's documentation:
"the Dell U2725QE's Ethernet port is part of the monitor's built-in hub and does not require the monitor to be switched off to disconnect your network connection; it is managed by the power state of the monitor itself and the connected computer."
Am I doing something really dumb - anyone any ideas as I really don't want to leave the monitor on all the time ?
