- Samuel
Hi,
I just got a set of negatives back in the post and after flicking through the prints I was horrified to find that about 7 or 8 of them just had a gradually darker area on the right hand side, like when you set the flash sync wrong but I wasn't using flash. The only thing in common each of the negatives had were they were shot using 1/500 or 1/1000 with the 1/1000 generally having a larger dark area to the extent of nearly half the frame in some cases. I now think that the problem might be related to the mirror, as few weeks ago when I shooting a landscape at 1/60, the shutter fired, but the mirror didn't rise as there was no viewfinder blackout or mirror slap noise. At the time I thought it was nothing as that was the first and only time it had done that.
I've checked the mirror foam to see if its sticky, but its fine; I know this camera was serviced about 3 years ago as the previous owner told me he had got it done. The picture below is an example:
Anyone got any other ideas before I start going about getting it repaired/serviced?
Its a pity as I was trying out the new Portra 400 and its an excellent film, I tried shooting it at 800 and 1600 on a couple of frames and they came out fine when developed normally.
