For anyone interested in Sunny 16 the top row here shows manually set Sunny 16 exposures for my 7D, 1D3 and 5D2 respectively. The second row shows the results of using evaluative metering and Av mode, with the 7D and 5D2 exposing a full 1 stop brighter and the 1D3 exposing 2/3 stop brighter. These were shot raw and are presented in Lightroom 3 with no adjustments.
The 7D had a bit of highlight clipping in the clouds and the football, the 5D2 in the football only. The 1D3 nailed it. That said, all the exposures have fallen within a manageable working tolerance, for raw captures. I suspect that if I had shot to JPEG the outcome would not have been so pleasant for the highlights when shooting in Av mode. You've got to be careful with these things when the highlights really matter, such as with a wedding dress or a swan's plumage. If in doubt check the histogram and have highlight clipping warnings enabled so you can check for overexposure where you can't afford to have it.
