- Tony
The question: I have three Elinchrom heads, each of which are fitted with the correct OEM 100w/196v modelling light; however, I’d really like to use something more powerful (at least 150w but possibly even more). Given that the lights themselves are 90-260v what are the constraints in terms of modelling light output? For example, I have a couple of 275w/230v bulbs from my old Bowen’s heads - could I use them if I wanted to?
The musings: I couldn’t work out why Elinchrom uses such a quirky power output scale on its lights; for example, my 500Ws heads are adjustable within a 5-stop range in 1/10th increments, but the digital readout is from 2.3 to 6.3 which, to be honest, is a bit irritating. Anyway, it turns out that this approach to output scales provides all Elinchrom lights with a kind of “equivalence”. For example, a lower power head might display an output of 1.8 to 5.8 or a higher power head with broader range of adjustment (say) 2.1 to 6,5; however, if all of these lights show the same number on their displays then, no matter what their power, they’ll provide exactly the same output of light, This has been tested many times, and it’s completely accurate... it’s ingenious, actually.
