- Brian
I'm hoping someone can help.
A friend has just moved into a new studio office where the router wifi is shared with a couple of other studios. He does however have a cabled ethernet socket in the wall.
Unfortunately, the wifi signal is almost non-existent and he needs a mix of wifi and cabled delivery.
Is it possible to plug an ethernet switch into the ethernet wall socket and then plug in something to the switch that uses the ethernet signal to create its own wifi signal. this will then allow him to cable his IT equipment from the switch and then use the wifi signal for his mobile devices?
Of this is possible could someone point me in the direction of the device he would need to buy?
I hope that makes sense and thanks in advance
