i use the calumet triggers and receiver. Well priced reliable and 4 channels
There's always the eBay standard Yongnuo RF-602s or RF-603s (603 are transcievers, rather than seperate models for transmiter and reciever).
The 602's are very well priced. My concern is that 99% of my work is in nightclubs that ere normally rammed, so I might lose em? Unless they do have a fastener.
Can you explain in abit more detail the differance between the Yongnuo RF-602s & RF-603s please
harryb said:They don't come with a fastener which could be a pain. I've never used mine when I've been working in clubs, my transmitter would probably fall off
As Silver Pixels has said, with the RF-602s you have a transmitter unit, and reciever units. They are different designs and requires at least 1 of each to work. Multiple recievers can be used with 1 transmitter (I often use 3 for studio flashes).
The RF-603 combines both the transmitter and receiver circuitry into 1 device. So as long as you have 2 or more 1 can be used as the transmitter and all others as receivers.
Beneifts are, if you for example, have 3, and 1 fails, you aren't potentially left without a transmitter or receiver, as you are with the 602s.
602s and 603s aren't interchangable, and as far as I know (happy to be corrected), won't work together.
A lot of people like and use the 602s, they are slightly older but very much a proven design![]()
I just bought the St-E2 cause I went to Calumet and tried their triggers. They do work very well but does not fire the infrared beam on the flash. I work in nightclubs so foocusing would've been a big issue as I was even struggling in a darkish Room. St-e2 works a treat!
Just to check, If I got a two pack of the rf-603, I stick on on my camera and one on my flash head, other flash heads can then work from picking up the first one firing?
Would you ever need to add other units to the other flashes?
