Battery Power in a Grip
  • Thread starter Thread starter whiteflyer
  • Start date Start date
W
whiteflyer
Guest
I normally use two BP-511A batteries in my grip, but being bored today and letting my little mind wander, I wondered would I be better using AA's.
My Thinking is
BP-511A 1500mAh X 2 = 3000mAh
AA 2700mAH X 6 = 16000mAH
So will I get 5 times as many shots with AA ??
My Thinking is
Mark,
Alas, no. There's an omission in your formula here and you'll get about 55% of the shots from your AA's versus 2 x BP511's
The BP511 is 7.4v so it takes the 6 AA's to provide the same voltage.
2 x BP511 at 1500mAh = 3000mAh at 7.4v nominal
6 x AA at 1600mAh = 1600mAh at 7.2v nominal
It's a good standby though.
Bob
AH! I knew there would be a reason to use the BP511's , luckily I got 2 for a tenner at 7dayshop. :)
Thanks Bob
