Budget Ring/Front Door Camera advice
Mr Bump
From under the bridge
Sophia aka Paul
I want to stick a camera on the front of my house watching the road, preferably with micro SD storage and able to access via app etc?
My house is a bit odd as the kitchen is the old shop so i have great window access, idealy i would like to put the camera in the top left window (above the green bin)
the bottom ones are frosted. We have good light at night as there is a streetlight almost straight out side the house.
the window has a large rebate on the inside so i could mount the camera easily. see pic.
Also i have easy access to power and wifi. I also have almost zero budget, thoughts?
Having one mounted on the window looking out will cause issues with the ir light in the camera. You may have to tape the IR light or switch it off if it is available.
yeah i did wonder that, the street is very well lit to be fair there is a modern LED lamp stand.
