Demand for
second hand is on the increase, which keeps EV resale price high (opposite of fast depreciating diesels) but it is still a depreciating asset.
So now you talking about depreciation figures on 2nd hand cars not new cars. I call that changing the goal posts to suit your own argument.
When have I said we are exclusively talking about depreciation for new cars? Look again at the bit you've quoted. "Demand for
second hand" car applies to cars of all ages. Don't be age-ist
Not sure what that demonstrates but may highlight that the mileage on a vehicle has a big impact on it's value, as 'most' EV's are town runabouts doing little mileage that may help explain the perceived low depreciation. Out of interest, try putting your Leaf into we buy any car with an inflated mileage (around the 25k per year area) and see if it makes a difference to the value, I'm genuinely interested to know if the Leaf is holding value on the back of supply and demand or if the low mileage (per year) is a factor.
I quoted 29000 actual mileage on my car, I've put on just over 10k in one year. For your amusement, I increased it to 50000 miles for this 4 year old car, WBAC returned £7000. That would mean £2100 depreciation for 31k miles in one year.
I personally think mileage isn't the biggest problem with EV powertrain. It is age and how it's left unused. There are very high mileage Tesla's and Leaf's around all showing minimal battery degradation. But age will slowly degrade the battery no matter how well you treat it. Then there's the low fuel dealership cars, battery doesn't like sitting at either extremes for long period of time. It's best to keep at 50% for long periods. But dealership still use the old method of not putting much fuel into the "tank". So personally, I would have no problem buying a newer high mileage EV, but I'd avoid showroom cars and cars sat in dealership for a while.
We're going around in circles. The current infrastructure delivered to houses isn't capable of everyone charging cars, come home at 6pm, plug it in.
Now there's ways around that, smart charging points that only allow charging when the system can cope, but the demand in an area is measured quite granually, it's not precise. Probably OK whilst we only use 7Kw charge points, but what happens when everyone steps up to 22, 50Kw and more and batteries get bigger to add more range. Then Ev's take off and everyone has two
Interesting conclusion from your assumptions. Why does everyone need to step up to faster than 7kW chargers? The car is sitting there for 12+ hours, what's the hurry?
22kW are only offered to houses that already has 3-phase. The supply current doesn't change from 7kW chargers. So your house can either install 22kW or 7kW, all on existing cable and all are limited to 32amps. Normal 1-phase domestic house has 100amp fuse. For comparison, electric showers are up to 11kW, how come substations doesn't trip in the morning?
7kW seems to be the de-facto speed car manufacturers put into EV's. There are a few cars that accepts 22kW using 3-phase, but not many. 32 amps AC charging seems to be the standard. To get higher speeds you'd need to install your own costly inverter, it just doesn't make any sense what so ever.
Consider this: Take 100kWh car for 300+ miles weekend away and Sunday night arrive home with 0kWh. 7kW charge up using E7 for 7 hours to 49kWh. Monday commute of 100 miles uses 28kWh, end of Monday has 21kWh in the battery. Tuesday morning after E7 charging starts with 70kWh, 100 miles commute come back home with 42kWh. Wednesday morning starts with 91kWh and you are pretty much ready for a long weekend away with almost full battery.
I never said it was ( certainly at present) but pointed to the fact that the infrastructure ( see quote above in case you missed it first time) can't handle the amount of EV's on the road,
in basic terms there are not enough charging points across the country as whole,
Infrastructure can be interpreted to all 3 things, now we've come to the last item
I agree.
Not much to say to be honest. I have successfully avoided using the dire public charging infrastructure completely after first few months to try it out. For driveway car commuters I don't see infrastructure to be a problem in adoption. Vast majority of charging should be done at 7kW destination (aka home) charging, public charging should only be used when driving away from home.
