Cataloguing contents of external hard drives but searchable when not connected. Help!
Steven
I've a load of external hard drives with various stuff on them. I used to have them all in my PC but the noise, power and heat wasn't needed as they were rarely accessed.
I'm wanting to take a snap shot or record of contents that would be searchable so if I'm looking something i can search on my PC and it'l find it and I'll be able to get the correct hard drive and connect it to my PC again to get the file.
I hope this makes sense.
Is there anything out there that would do this?
You can place all the files in folders by date order or alphabetical order and then copy them into the drives and mark each drive with the contents.
Drive 1 2004 - 2006 or A to D
Drive 2 2007 - 2010 or D to H
Drive 3 2011 - 2016 or I to N
etc
etc
etc
I use a piece of free software called TreeSize that'll list everything on a drive and allow you to print the result. Perhaps you print it as a searchable pdf?
etc
etc
etc
I'm looking software that holds a record of the contents of each drive that I can search even when the drive isn't connected so I know which drive the file I'm after is on. I'll have all the drives marked either numerically or alphabetically with a big sticker so I know which one to connect once I'm told which drive it's on.
How many files are we talking about?
I can't see how any software can find the exact file you want with the info you have told us, unless you have tagged every individual file with the full data?
go to the run menu and type CMD. In the box that opens, type
dir x:\ /s >> ~\Documents\directory_of_files.txt
where x is your drive letter. Repeat with all your drives changing just the x
This will create a text file on your Documents folder with the name of every file and the drive it's on. You can easily search this with a text editor.
E.g.
This looks like it might be what you're after. It's not clear how it handles arbitrary non-media files.
the free demo version is limited to 10 drives.
Edit; Or this, which looks the better general solution.
I've found something. It's called Snap2HTML, it's free and looks to be what I'm after.
Juts having a look.. Going to download that myself as I have a few hard drives knocking about.. could save me the pain of plugging them in seeing as some require plug as well us usb.... thanks :)
ADDYONBIT
THIS IS BRILLIANT! Works perfect
722046 files in 18415 folders (1.23 TB)
I have half a dozen more HD to catalogue :)
I no longer have to plug in multiple hard drives if I have lost a file and need to find it
hope it works as well for you @wilt :)
E.g.
Just what I was about to say!
A Microsoft article on the above
E.g.
Sometimes the simplest solutions are the best
