D810 chroma noise at low ISO...
sk66
Advertiser
Steven
I've started doing a bunch of low key dark on dark/ black on black images and I'm finding a lot of chroma noise in the D810.
For instance, here is a 1:1 crop of a tiny section of the image posted here:
Screen Shot 2014-11-09 at 9.14.48 AM
by sk66 on Talk Photography
That crop is AFTER noise reduction and even an HSL layer tyring to get it to smooth out. The image is not a low light/natural light/long exposure...
Now, I know that 1:1 critiquing of an image over 7000px wide is overkill.
And I know that some chroma noise is common in dark areas where the sensor really doesn't have much to work with.
And I know higher ISO's will make it worse.
But I'm finding it pretty bad even at ISO 100/200 (which look the same to me). And I can't find a good way to really deal with it.
I'm guessing it's just a factor of the high MP count? Anyone else experiencing the same/different?
(some of you may not be able to see much of anything in the crop... monitor calibration will make a big difference in seeing it)
How are you exposing / processing? Are you boosting the image at all post capture or exposing to the right?
Pretty much as captured... a little gamma shift to get a bit more separation.
After the issue became apparent I decided to try exposing to the rt and pulling down. Works fine for higher contrast, but I can't tell if it helps w/ "grayscale" tonality.
Just doesn't seem like it should be required at base ISO...
I looked at some of my A7 (24mp) files at 100% and couldn't find any that looked like yours even with ISO's into the k's. To try and get somewhere near your shot I shot a sparkly smartphone case against a black fibre background with shadow in shot too without ETTR, the cursor was smack in the middle of the exposure scale, and again at 100% I couldn't get anywhere near your results.
So, dunno. Sorry.
I wonder if it's because it's black BG paper... it has a slight texture. (Savage super black #20)
I think that makes sense as it's really only apparent in shadow transitions...
