So ' Chez Nod ' has only now fired up the CH ! Let me guess . . . you live in Suffolk and benefit from radiated heat from nearby Sizewell B.Consumption will rise here now - Mrs Nod decided that it was time to put the CH on yesterday evening. Just in time, probably - I had to scrape the windscreen this morning!
Iirc it used to work exactly opposite to that. Cold weather payments were triggered when the temperature hit a certain number. This was lower in the North because "they were used to it"I do think there is an argument to be made that the further north you live the more H.M.Gov should help with your fuel bills ? I am a little biased of course, but would
not begrudge Northumberland residents getting more than me. . . . Just as long as I'm getting more than 'south coast softies'.
I also like your thinking. Sadly it would probably be that complicated (if even possible) and expensive that it would cost as much again as the actual assistance. And as a finalIn my view it should be compound formula to help target help where it is most needed, combining several factors (no single one works) in something like a points based system. Anyone on benefits goes straight to the top, council tax band, location in country, health conditions etc. That would make one heck of a complicated system that likely would have almost as many problems as it solves, but as the only thing I run is an armchair not a country I'm at liberty to think it would be a good idea.
This was lower in the North because " they were used to it " Really ? that's outrageous if correct.Iirc it used to work exactly opposite to that. Cold weather payments were triggered when the temperature hit a certain number. This was lower in the North because "they were used to it"
I genuinely think it would be easier (and probably cheaper) to nationalise power generation and make it affordable for all. Invest heavily in renewable power and schemes whereby new houses have net zero power requirements, estates are heated by communal schemes and everybody has enough money to start warm.In my view it should be compound formula to help target help where it is most needed, combining several factors (no single one works) in something like a points based system. Anyone on benefits goes straight to the top, council tax band, location in country, health conditions etc. That would make one heck of a complicated system that likely would have almost as many problems as it solves, but as the only thing I run is an armchair not a country I'm at liberty to think it would be a good idea.
Yeah that's what I remember. Right around the time that nice Mrs Currie was telling older people to knit hats.This was lower in the North because " they were used to it " Really ? that's outrageous if correct.
You need to look at a 'secondary return' unless you have a combi boiler. Also make sure pipes are insulated.Our bathroom is at the back and the boiler is at the front of the bungalow. I tend to use the shower mostly as it is heated at the delivery point. The sink takes at least two minutes to run through hot and then all the hot water in the pipe is wasted as it just cools again! We've been looking at an undersink heater to avoid the waste.
Well they do say men are from Mars and women are from Venus.........and Venus is one heck of a hot place (as we know now)Mrs Nod is a Northener while I'm born and bred soft, Southern nancy but it was her who put the heating on!
Hmm ! Nationalisation. that 'old chestnut' We have to accept privatisation is the way forward, promoting competition, increasing efficiency, and lowering costs.I genuinely think it would be easier (and probably cheaper) to nationalise power generation and make it affordable for all.
But that's hardly a Conservative point of view.
Just received a letter from Octopus energy containing the following paragraph:
An email from Octopus Energy
Looking further ahead, based on current plans, energy prices will rise a further 20% in April — taking a typical home annual bill from around £2,500 to £3,000 — as the Government scales back the amount of support available.
With the £67 monthly credits from the Energy Bill Support Scheme also ending in March, we know April is going to be a difficult time for many.
Well, it depends. We often get snow and associated weather in april. Of course bills should be lower after april but will folk be able to build up a credit for the coming winter ?Its not April thats going to be the issue, as energy consumption reduces in the summer months, its next winter!
New Worcester Bosh oil boiler installed outside in 2018 was £4.5kI wonder how much you can safe on installing a new boiler. I have 15 years old Vokera.
but then if its worth doing it, while new oiler can be £1000-2000, installation same, around £2k.
Unless I could get some cowboy to install it for me
Scottish Power or British Gas would be even more expensive.
Anyone installed new boiler lately? How much was it?
The 'old' boilers have cast iron heat exchangers, these heat exchangers last for ever but are slow to heat up and inefficient. Modern boilers may use copper, aluminium or stainless steel heat exchangers. All have advantages/ disadvantages. They will heat up far quicker than the aforementioned 'old' ones and are far more efficient i.e Gas in / Heat out. They will not last anyway near as long as the ' old ' ones. Of the 3 a quality stainless steel heat exchanger will probably last the longest in a domestic system.I have an Ideal Mexico Super RS100 boiler that is a bout 35 years old. Every time I get it serviced I ask about changing it for a new modern combi boiler.
They have all said don't bother as they don't last and I can still get spares for it.
We had a new boiler installed 12 months ago at a cost of £2500 ish to replace an 18 year old one.New Worcester Bosh oil boiler installed outside in 2018 was £4.5k
It was a few years ago now, but I'm sure it made a difference, (semi detached)Cavity wall insulation, I've wanted to get this done. Did you find this useful at all?
Thanks for the heads up.Octopus also have the tracker tariff, it is the cheapest by miles. https://mysmartenergy.uk/Tracker/Southern-England
I've just checked my area, ( east midlands) Electric 16.8p v 32p and gas is 3.6p v 10pOctopus also have the tracker tariff, it is the cheapest by miles. https://mysmartenergy.uk/Tracker/Southern-England
Time to resurrect this thread
I'm sure EDF are taking the proverbial,
I pay £233 / month, a late 60's place, 4 bedrooms, double glazing and cavity wall insulation.
They guesstimated a 10,000+ Kw/hour on gas, I just checked and this last quarter I actually used about 10% of that.
So that works out to about 40% of that, over the year.
Electric, 3000+ Kw/hour That's about the same as last year ( no real surprise 2 x 100x heaters on a thermostat for the snakes and a pond pump and UV filter ( 36w/hour) running 24/7
I looked on Octopus and going on last years figures from EDF it came out at less than £100.
Going on this years EDF guesstimates, its a fraction over £200.
The trouble is EDF don't make it easy to find these details, I guess they don't want me to swap.
My yearly contract runs from August to August, I could swap now and hope to save £30 / month ( no penalty for leaving)
Or wait until August and get the actual figures from the past year, and see if EDF drops my payment,
or I have something concrete to take to octopus.
It does seem favourite, its been recommended by a few people over the months,While I cannot comment on the potential savings (if any) from switching I will say this. I have now been with Octopus Energy for approx 2 years.
Over 40 years, and changed suppliers several times over the years, so no, no historic records.You've lived in the house for over a few years? Have you got historic meter readings?
As above, no.have you got a record of those over time?
As above, no.
I never felt the need to keep records, EDF only goes back 2 years, and again, as above they are grossly over estimating the gas usage, electric remains fairly stable.
I heard a rumour that it was because they deserved it....Iirc it used to work exactly opposite to that. Cold weather payments were triggered when the temperature hit a certain number. This was lower in the North because "they were used to it"
