Beginner Help with landscape settings
Tom
Ideally it would be good to know what settings you actually used.
In a situation like this - ISO100, on APS-C around f5.6-f11, shutter speed dependant on those other two variables and obviously dependant on whether you had a tripod. Manual focus would help as well.
Personally I don’t think they look too bad and you have controlled the light well, if you want the best from the images though, SOOC JPEG won’t cut it form landscape. You need to shoot RAW and edit the images yourself.
OP
OP
T
settings wise i just set the dial to the landscape setting, So I think everything is automatic on that, I can check later though. I do save just as large jpeg, not raw. I will change that, and i'll make a note of those settings. thankyou :)
The scene is predominantly white, your meter will assume it be average grey. It seems to have preserved the highlights so that's good.
Looks ok to me, just needs a bit of editing to bring it to life.
It looks much nicer edited, what did you change?
Jeremy Moore
Yes, your main problem technically for these is that you took the meter reading as gospel. In a very bright situation like this your meter will read the scene AS IF it was average grey, and the image will be underexposed. That is how meters are calibrated.
You need to recognise when this will happen and over-ride the meter by adding about 1.5 - 2 stops of exposure.
In other words 1/250 th at f8 should become (about) 1/60th.
Also you don't need to use a landscape preset. Using aperture priority for landscapes, all you need to know is what aperture to use and the camera will set the shutter speed. In a case like this there is nothing in foreground so f5.6 or f8 will be fine.
Graham
@Tom30 I used Lightroom but any program would do a similar job.
I increased the "Exposure"* to make the whites a bit more white. This caused the bright parts in the sky to blow (as it would) but because you had preserved them in your original file it was possible to get them back by by bringing the Highlights slider down a bit.
That set the "Exposure" to where I would like to see it, I then increased the vibrance a bit (It's more subtle than the saturation slider.) finally a bit of clarity for a bit of oomph.
Very quick and basic stuff really.
Had your jpeg come out of your camera this bright you would have almost certainly blown the highlights for good, so I reckon your camera got it about right under the circumstances.
* I don't like the term "Exposure" when used in editing software. Exposure is something that happens when you press the shutter and is a combination of shutter speed, aperture and sensor sensitivity. I think "Brightness" would be a better term. :)
Kev
Here is a copy of a reply I posted to a similar question.
The first thing to realise is that the light falling on a scene determines what the exposure should be, the light reflected from a scene varies according to what is doing the reflecting. As camera meters measure reflected light this can cause problems. If you were to measure the light falling on the scene, using an incident light reading, you would not have to worry about adjusting exposure for different scenes which reflect different amounts.
Your camera is taught that all scenes reflect 18% of the light falling on them (Digital cameras may be taught that it is 14% or 12% depending on the camera but I will continue with 18%)
First consider taking a picture of a landscape which, on average, is reflecting 18% of the light falling on it.
When your camera is pointed at the landscape it thinks ' That scene must be reflecting 18% of the light falling on it so I need to set an exposure to suit that light. '
If the light gets brighter the camera thinks ' That scene is still reflecting 18% but it is brighter now so the sun must have come out so I need to reduce the exposure to suit the new brighter light '
If the light gets dimmer the camera thinks ' That scene is still reflecting 18% but it is darker now so the sun must be behind a cloud so I need to increase the exposure to suit the new dimmer light'
So far so good but what about scenes which reflect more than 18% such as snow.
When your camera is pointed at the snow scene it thinks ' That scene must be reflecting 18% of the light falling on it but it is very bright so it must be very sunny so I need to reduce the exposure to suit the very bright light '
This means that, although the camera meter shows the exposure as correct, it has actually reduced the exposure and will cause the white snow to be grey.
A similar thing occurs when you photograph a very dark scene, a black horse for example.
Your camera thinks ' That scene must be reflecting 18% of the light falling on it but it is very dark so it must be very overcast so I need to increase the exposure to suit the very dim light'
This means that, although the camera meter shows the exposure as correct, it has actually increased the exposure and will cause the black horse to be grey.
Having read and hopefully understood all that many digital cameras have an in-built library of shots which your shot is compared with, the camera can then think 'OK that shot is very like the snow shot that I have in my library so I will overexpose it a bit' I am only familiar with my Nikon and that compares shots with its library when it is in Matrix metering mode and not in the other modes.
The best solution to all the above is to use the histogram, this will show you what you have recorded and you can can use exposure compensation to get the correct exposure for that particular shot – making whites white or blacks black.
There's nothing wrong with number one, I'd be happy with that as my raw file and then lift the brightness as the edited version shows. The composition isn't as nice in number two. It's very hard to give fail safe settings because it depends on the light, foreground, wind conditions, handheld or tripod etc. Ideally apertures between f8-f11 for wide landscapes and the lowest ISO but if it's very windy you're probably going to need a fast shutter speed and increase ISO to keep the image sharp. Can be better shooting handheld in extremely windy conditions too, all depends what you have at the time.
Graham
Had a quick little play myself just to see how far I could push a jpg and bring a little (ok a lot of) colour into the scene.
I’m sorry to intrude on this thread... I hope that’s ok? ... this question and your replies made me think about snow pictures... I know that the camera will be fooled into thinking it’s much lighter than it is because of the snow so one needs to compensate for that. I thought that is best done by using the exposure compensation dial? You suggest it’s done by prolonging the shutter speed?
If you are in manual mode, EC doesn't always work (it depends on the camera model). Personally, I would use EC in Av mode but then I rarely use manual exposure.
Mike
Its the same thing.... its a question of 'Metering' and the way you translate that meter-reading to camera settings.
The SI unit of light intensity is the Lumin. If you ever chance across a scientific or industrial light-meter, that's how it will be 'calibrated', with a scale marked in Lux... and a bit more peculiar in that it's a normally logarithmic scale... and almost utterly useless to help any-one trying to take a photo.
If you are trying to take a photo, what you want to know, is what 'settings', of Aperture, Shutter-Speed and ISO you need to use to get a picture that's not too dark or too bright..... See Exposure Exposed because there is actually no such thing as a 'correct' exposure, let alone one that you can get from a super-scientific light-meter 'reading'.. its mostly down to intent and personal preference, and trying to force a set of one-size-fits all rules onto metering, is a bit like telling people how much salt they should have on thier crisps.... some might actually prefer prawn cocktail!
So, if you pick up an old fashioned hand held photographic light meter.... it has a scale marked in EV or 'Exposure Values'.... still not quite what you want to know... but a little more convenient than Lux! I conveniently have my old Leningrad Selenium cell light-meter to hand. Incidental aside; its a clever bit of Russian cold-war era technology, the selenium cell makes electric from the light falling on it. The swing needle is then actually a simple volt-meter, that moves the needle more, the more volts the cell makes, cos the more light that's falling on it... means it don't need batteries! But.... the needle swings across the scale, and rather than being marked in Volts which actually whats making the needle move, or Lux whats making the volts to make the needle move... its Marked in these EV's.... from EV8 to EV14, because thats the 'high' or 'daylight' range. There's actually a switch that changes a resistor in the Wheatstone bridge circuit behind the galvanometer so that it can react to lower light, the 'low' or twi-light range, and actually moving that switch pulls another scale down behind the needle to read from EV1 to EV9... like I said, wonderful Cold-War era Russian technology!
Anyway, beneath the EV scale is a little mechanical Computer! Basically two discs on a common axle, and a few arrows! It was designed for 'film' and we tended to be pretty much stuck with whatever ASA film speed or 'ISO' sensitivity that was, so the first thing I do is set the 'ISO' setting in a window of one of the discs. Then I line up the EV I read off the scale, on the outer-disc with the arrow... and that brings shutter-speeds into line with corresponding Apertures... and I get perhaps 8-pairs of aperture and shutter-speed settings I can choose from that all offer the same 'exposure' for that EV at that film-speed... sounds more complicated than it is... BUT... significant thing is that I get a RANGE of settings I might use, not just one.
More... I can take a light meter reading in one of two ways. I can go stand in the same light as my subject, and take an 'incident' reading of the light actually falling 'on' the subject.... or I can stand back, where I am holding the camera, point the meter at my subject and take a 'reflected' reading of the light bouncing 'off' the subject.
Oft said that an incident reading is more 'accurate' than a reflected one, but pedant in me says no, the accuracy is how close to target the result is... both can be as accurate or inaccurate as they may be... what they mean is that an incident reading 'tends' to be more reliable... and give you a reading that more often results in a good or pleasant exposure... but as said, see the tutorial, there's no such thing as a 'correct' exposure.....
And in this instance, with a predominantly white snowie scene, an 'incident' reading is probably more 'appropriate' than a reflected one, because all that snow will reflect a lot of the light falling on it.... and as has been mentioned, most reflected metering schemes have an inbuilt flaw in the presumption that the scene will reflect about 18% of the light that falls on it..... so if you take a reflected metering of a black-cat in a coal hole, its going to give a lot lower reading than if you took a reflected reading of a white rabbit on a ski-slope, BUT, assuming that 18% of the light falling is reflected... when you translate the EV to 'settings'... you would tend to make settings that under-expose or make dim, the white rabbit on a ski-slope, or over-expose, make bright, the black-cat in a coal-hole.... if you used an incident reading.... you measure the light falling on the subject, not reflected off it, so you should get the same 'reading' for both scenes, and not over-expose your cat or under-expose your rabbit.... whether you could see either in the resultant photo, and if you could, whether you 'LIKED' that exposure, is an altogether different matter.... like I keep stressing... there's no such thing a a 'correct' exposure!
BUT this brings us to the matter of exposure compensation.... which is essentially NOT taking the numbers as gospel, and applying a bit of judgement WHEN you turn an Exposure Value into 'settings' or in picking the settings you actually use.
In the case study presented, the 'essence' is that the predominantly bright white scene has come out 'under exposed' and a bit grey. Hence to brighten it up a bit, adding a bit of compensation.. and letting in a little more light than the meter suggests... which you could do by either manually setting a longer shutter speed, OR by telling the camera to do that 'automatically' using an exposure-compensation dial.
NOW! Using Exposure-Compensation, on a dial, on the camera.... what that does, is tell the camera to pick settings to use, that will make the final photo brighter or dimmer than it 'thinks' it aught to be, just from the meter-reading it got.
Doing it manually, you pick an alternative shutter speed or aperture or ISO, to what the camera 'suggests' to make the photo brighter or dimmer.... and here we have to consider how the camera's meter is 'coupled' to the settings..... because if you want to brighten up the picture, you could just select a lower shutter speed.... but the cameras electrickey could just as easily over ride YOU, and as you add say one stop of shutter, reduce one stop of aperture or one stop of ISO, to keep the exposure what IT thinks it should be, going by the meter!
So its all ways to skin that black cat in the coal-hole.... and the important thing is to note that there are two ways to meter a scene, reflected and incident, which may be more of less expropriate or convenient in different circumstances. Having got your meter reading... you then have to translate that it to more or less appropriate 'settings' by way of aperture, shutter and ISO.... and you can pick many many combinations of the three that ALL result in the same exposure.... BUT is that 'exposure' the one most pleasing to you?
If you see tutorial, you can get an exposure that makes an 'acceptable' picture, across a range of perhaps six stops of Exposure Value... in fact, in the tut, I think that I showed more or less 'acceptable' photo's six stops either side, so twelve stops range... any of which might be more to your preference.... BUT the camera only takes ONE meter reading.... and assumes you want an exposure slap in the middle of that range....
Interesting 'point;' here, is that the OP 'prefers' the exposure that his smart-phone chose for him, to the one that his Digital SLR did...... neither are 'wrong'... both are photo's, BUT one is more pleasant than the other.... in one opinion....
There's also some small revelation in the OP's comment about the fact that it was too cold, he didn't feel inclined to faff about to much, and 'just' left most of the job and decision making to the machine. And there in lies the 'nugget'. The camera-phone picked 'settings' the OP 'liked better' pretty much by happy-chance. The DSLR didn't, similarly, mostly by chance....
If you leave it to chance? You get what the camera gives you. The 'lesson' here is that to get what you want... you need to know what the camera is doing, and how its going to give you what you want..... or not.. and if not... what to do to MAKE the camera give you what you hope for.... which means YOU cant just leave it to chance, you have to do some work, which probably means faff, and putting up with the cold, or inconvenience... and its probably THAT 'diligence' or often shear bludy mindedness! that most often separates the OK, from the pretty good, from the excellent, as much as applying the small extra know-how, and faffability of not just leaving it to chance and the programming mushrooms that made the decissions you cant be bothered with.
