I've had my highlight out a few times and I am starting to notice an issue with it.
Firstly I'm having trouble getting the setting right using a light meter. Can get the background to somewhere between f11 and f16, but can't seem to get the key light much higher than that. Thing is the photos don't come out too bad but I'm not sure what I'm doing wrong.
The rule of thumb seems to be Key light set to f/8 (And what you set the camera to in M mode), Hilite anywhere from f/11 to f/16... If you tried to match f/11-f16 with your keylight, that's a problem, the aim is to set the background brighter then the subject, and you are metering for the subject..
Looking at your image, the amount of light 'wrap' from the left and lack of brightness on the right of the Hilite is something you can look at. I've been using 1 light in mine, but I angle it slightly towards the back of the highlight (aimed roughly at the center of the back wall of the Hilite), that gives me f/13 - f/13 - f/11 accross hilite (6 x 7), that's using a standard reflector on the strobe, without the reflector, I get hot spots on the side the strobe is, and it's not that great.
