- Alastair
My second D700 massively underexposes when the non-cpu lens data is set to a lens with a max aperture greater than f2.8. So if I set it to my 55mm f1.2, I get underexposure and vignetting in the top left of the frame, even if I chuck a different lens on, such as an f2.8. However, if I change the setting to any lens with a max aperture of f2.8 or higher, then the problem goes away on any lens I chuck on. I have just updated the firmware, as 'An issue that, in some very rare cases, caused images to be extremely under-exposed has been resolved.' Not this issue tho. I have checked other forums and found a person on Flickr had the same issue, unresolved.
Any thoughts? No, I can't return it, no warranty!
